Toàn quốc [SLaudio] Aune T1 Mk2, Aune S16, AUne X1 Pro, Aune X2 MK2 chính hãng
Thảo luận trong 'Mua bán - Rao vặt khác' bắt đầu bởi taingheviet, 23/3/15.
  1. taingheviet Member
    SLaudio-taingheviet.com
    Điạ chỉ: số 4, ngõ 4, phố Trần Quý Kiên, Cầu Giấy
    Điện thoại: 0932347414 - 04.62811546
    Website: www.taingheviet.com
    Email: taingheviet@gmail.com
    Aune T1 MK2
    Giá bán : 3.999.000 VNĐ
    Thông số kỹ thuật :
    Frequency response : 20Hz - 20KHz
    Line Out : 2Vrms
    Support Driver Impedance : 30ohm-600ohm
    USB support : 24Bit / 96KHz
    Amp output : 32ohm --- 1000MW 120ohm --- 400MW 300ohm --- 150MW
    Headphone jack : 6.5mm
    Line / LO output : Internal decoder analog audio signal output interface
    Line / LO input : external analog audio inputs
    Input switch : Line / USB input switching DIP switch gear
    USB Interface : USB-B female input interface
    Gain adjustment: amp output gain adjustment
    N.W: 800g.
    Aune B1
    Giá bán : 4.499.000 VNĐ
    Thông số kỹ thuật :
    Portable Amplifier Class A
    Gain adjustment: +5 dB or +15 dB
    Adjusting the current 20 mA or 40 mA
    Headphones: 16-300 ohms
    Frequency response: 10 Hz - 20 kHz (+ - 0.15 dB)
    SNR: 124 dB
    THD + N: <0.0008% @ 1kHz
    Crosstalk: <110 dB @ 1kHz
    Output Power: 25 mW / 16 ohms, 50 mV / 32 Ohm, 100 mV / 300 Ohms
    Weight: 0.23 kg
    Size: 110 * 65 * 18mm (L * W * H)
    Aune X1 Pro
    Giá bán : 3.500.000 VNĐ
    Thông số kỹ thuật :
    Inputs: Optical, Co-axial, USB and RCA Line in L/R pure copper gold coated
    Outputs: RCA L/R 2Vrms
    Headphone Amplifier: 30-300ohm headphones recommended
    Headphone Output Jack: 6.5mm with 3.5mm adapter provided
    Headphone Output THD: 0.05%
    Headphone Output Level: P-Pmax 10V
    Decoder: Wolfson WM8805 + PCM1793
    USB Interface: SA9027 Asynschronous
    Sample Rate:
    - Optical/Coaxial: 32Hz to 192kHz
    - USB: 44.1Hz to 96kHz
    Bit Rates: 16, 24, 32 bit
    Frequency Response: 20-20Khz, (+/- .05dB)
    THD+N: 0.00227% (-92.8dB) @ 20kHz
    Crosstalk: <-101dB@1kHz; <-85dB@20Hz - 20kHz
    Output Linearity: +/-3dB@-95dBFS
    Output Signal Noise: -98dB@20kHz
    Power socket: (5.5mm/2.1mm) x 1
    Face plate: CNC machined aluminum
    Connectors: High quality Gold Plated RCA
    Size: 13.5cm (5.3") x 5.1cm (2.0") x 17cm (6.7") (W x H x D)
    Weight: 1.5kg
    Aune X2 MK2
    Giá bán : 2.550.000 VNĐ
    Thông số kỹ thuật :
    Frequency : 20-20000HZ+/-0.5dB(8ohm purely resistive load 1W-10W
    Power 30WX2,8 ohm
    THDsmall than 0.02%10W,8ohm,1KHz
    SNR more than 88dB(1KHz
    Power Input : DC24V
    Size chassis 135*51*170 (mm)
    Weight : 2KG
    Aune M1
    Thông số kỹ thuật :
    Weight - 6.4 oz (181.44 grams)
    Size - X X ( 10.31cm X 5.6cm X 2cm)
    Battery Life - 7+ Hours
    Charge Time - Less Than 2 Hours
    Asynchronous Clock (Nonsynchronous)
    Super-low Jitter Clock Crystal
    0db Background Noise at Full Volume
    Impedance 32 - 320 Ohms
    Playback Format - wav only
    Output - SPDIF Coaxial, 3.5mm Headphone
    Storage - SD card up to 32Gb
    Aune S16
    Giá bán : 15.000.000 VNĐ
    Thông số kỹ thuật :
    THD + N: -116 (balance -3dB)
    -112 (Unbalanced -3dB)
    -106 (Unbalanced 0dB)
    News: 118dB
    Separation: 120dB
    Intermodulation Distortion: -98dB (60Hz, 7KHz)
    Background noise level: -145dBFS
    SNR: -118DB
    Effective low noise voltage: 4uV (10-100KHz)
    Parameters:
    Input Interface
    USB:
    Maximum world length: 32Bit
    Maximum sampling rate: 384K
    Maximum DSD rate (DOP): DSD 128
    AES:
    Maximum world length: 24Bit
    Maximum sampling rate:192K
    Maximum DSD rate (DOP): DSD 64
    COX:
    OPT:
    Typical Line Output Indicatiors
    USB:
    Output voltage level@ 0dB: 5.6 V rms
    Frency response (from 20Hz to 20KHz): ± 0.5 dB
    Dynamic range: 118 dB
    THD+N @ 1KHz: -100 dB
    IMD + N @ 19KHz& 20KHz: -111
    Stereo crosstalk: -115
    RCA:
    Output voltage level@ 0dB: 2.8 V rms
    Headphone Output Power:
    @ 600 Ohms 300 mW
    @ 300 Ohms 600 mW
    @ 120 Ohms 1500 mW
    @ 32 Ohms 3000 mW
    Các sản phẩm Aune đều là hàng chính hãng, bảo hành 12 tháng .
    Call Mr Sơn : 0169.6199.836 để biết thêm thông tin về sản phẩm !
